Oh you remind me! I have a bit of experience with filaments partially
short in 120V lamps from shock/vibration!
I have seen that happen with filaments of C-7A and CC-2V style.
In the case of C-7A: Nightlight lamps and similar 120V holiday lamps,
when tapped in rough manner by a finger (plucked), especialy if
impacted such several times, can have a small region of filament get
tangled with a small region of a nearby portion of filament.
This appears to me to occur more easily if impacts (with the filament
hot) stretch the filament so that the filament has slack and sections of
it easily flopping around.
I used to do that a bit as a "party trick" - to make such lamps glow
brighter and whiter. That was maybe 30 years ago, and back then I was not
thinking that much that I reduced the lamp's life expectancy to maybe a
few days.
On a bit of a sidetrack, those lamps had bulb shape/size designation of
C7 and a common nominal wattage for those was 7 watts. Since then there
have been 4 and nowadays some 5 watt ones with C7 bulb and C-7A filament.
There is a larger usually-colored "older type holiday lamp" with bulb
shape/size designation of C9. Its wattage is typically 7 or 10 watts and
the filament is usually C-7A. The base of that one is often "intermediate
screw", which often makes the part number get an "N" towards the end.
In the case of CC-2V: I forget whether that was "normal CC-2V"
(pointing away from base) or inverted (and I wonder what the designation
for that is anyway). However, those were V-shaped coiled-coil filaments
with one support at the "corner" between the ends.
The lamp was a chandalier style one, of wattage probably 40 or 60 watts
but I can't rule out 25, and the bulb was of one of those F or similar
flame shapes.
Where I saw such lamps having filaments partially shorting, the
filaments had a short somewhat close to "the vertex of the V", apparently
due to vibration/shock jostling the filaments and possibly stretching the
filaments also to make the filaments entangle into such "partial shorts"
more easily.
Where I saw such CC-2V filaments shorting was in a fraternity house at
the University of Pennsylvania (when I was making a delivery to that
house), back in a day when fraternities at U-of-P had an easier time
having parties with beer kegs in their houses. The affected/afflected
filaments appeared to me especially "stretched/floppy", except the ones
that partially shorted but had yet to fail appeared to me "not-too-floppy"
(and also appeared to me having fair to poor chance of surviving into the
next party).
I did appear to me that the filaments were stretched into a "floppier
state" and I happen to think that the filaments were stretched into an
"easier-to-partially-short state" while the filaments were hot, as in
"in-use to produce light".
As for shorting effects specific to coiled-coil where "greater turns"
short to adjacent ones - that one I have yet to see, but I don't yet have
doubt that this one can occur if the "greater turns" are wider and/or
the "compacted overall length" is shorter than usually used in coiled-coil
C-6/C-8 filaments in 120V A19 lamps.
- Don Klipstein (
[email protected])
