How do I run a 12V 3A monitor (made for a car) into a home AC outlet?
I've got a 7 inch external monitor I want to set up with my camera, it
is made for a car 12V. Now, what do I do to make it so I can run it
from my home - AC? I don't want to take a chance trying it with an AC
adapter before I figure this out. Any ideaS?
Jerry G.
Go out and buy a 12 Volt 3 Amp power supply. Most of the electronics
parts distributors sell these.
Jerry G.
F
Franc Zabkar
A 36W AC adapter will be relatively expensive. I'd use an old PC PSU
instead.
- Franc Zabkar
DaveM
I recommend that you get a desktop power supply unit to power the display, such
as the ones at MP Jones Associates:
http://www.mpja.com/productview.asp?product=14702+PS
and
http://www.mpja.com/productview.asp?product=16168+PS
Similar power supplies are available elsewhere, but these are priced right.
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
address)
Never take a laxative and a sleeping pill at the same time!!
Why not use a car battery? Then you can use it when AC isn't available.
David D
I like the price of these - if I can run it right from the monitor to
an AC outlet, that would be ideal!
So am I right in assuming if the monitor says 12V 3A - then one of
these will work with it?
James Sweet
Yes, they'll work just fine.
Dave D
That takes me back to my early Amateur Radio days, running my rig off an
on-charge 12V car battery on a tray in case of acid spillage! I used to keep
the window open in case of hydrogen build up.
A car battery is not something I'd want in my house now, but it would
certainly do the job the OP wanted.
Dave
DaveM
Yes, you should be able to use either of the units with your display. You might
have to cut the coaxial connector off the cable and wire directly into your
display.
Just make sure that you have the polarity correct. Measure the voltage on the
wires with a voltmeter before you hook it up. Power supply (+) goes to display
Dave M
address)
