tempus fugit
Couldn't you just use an IC regulator like LM 317?
Creamed_emu said:I recently build my first valve preamp but the powersupply i threw together
creates quite a bit of noise on the output. I needed a cheap regulated 66v
supply so i put 2 33v zenners across the Cap on one of those cheap
disposable camera boards (probably not the best choice) The setup works fine
except for the 10khz squeal, i've tried adding extra caps in parallel but
there is no noticable difference. There is less than 1ma being drawn from
the powersupply.
Any ideas?
tempus fugit said:Couldn't you just use an IC regulator like LM 317?
the powersupply.
Any ideas?
