I purchased a pair of car horns from sparkfun (https://www.sparkfun.com/products/10966?)
The potiential power draw has me a little concerned.
Rated Voltage: 12V
Rated Current: 8A
1)Do I have to provide that much power, or will it function quieter after some "on" threshold is met?
2)Assuming the whole 96 watts isn't required could I power one of these off a small wall wart (300ma)? What happens when a potientially large load is attached to a small supply? Will the supply only provide its rated maximum? If not could I limit the current with a suitably large resistor?
3) Do I need to worry about running this through a standard breadboard or regular hookup wire given the wattage?
Thanks, sorry if these are newbie questions.
Rated Voltage: 12V
Rated Current: 8A
