How do I decide what size motor to use as a generator?
I'm currently prototyping a sort of wind turbine project and I'm trying to figure out what size motor to use to get x amount of volts. I'm wanting to make a small scale one first before trying a large one. What I'm aiming for as of now is only about 1.5-3 volts. Is there any type of equation to figure this out? Like with rpms and voltage of motor being used etc.?
You specification is incomplete. You need to know both the current and the voltage. The voltage out of a generator will be high with no load and drop with a load (i.e. current).
I am not an expert, but I think the place to start would be to choose a motor whose voltage and current are somewhat above what you want to generate.
Bob
