How do ADCs tackle negative value analog input ?
Could some electronics guru please shed
some light on this ? First of all, may
I point out that my work so far has
involved either pure analog or pure digital
circuits, with hardly any analog-digital
conversion or vice-versa. So my questions
might sound silly to some experts. Here we
go.
Suppose I am sampling an audio signal, whose
raw voltage levels range from +2.5 Volts to -
2.5 Volts. I understand that a sigma-delta
encoder could tackle this, but can a flash
ADC or successive approximation ADC tackle
this ? If not, is there any viable modification
so that the last two ADCs can handle it ?
Thanks in advance for your comments/thoughts
on this.
Rocky
on this.
Depends on the specific ADC. If it has an input range from +2.5v to -2.5v then it will work fine. If not you will have to scale your signal and possibly add an appropriate offset.
go.
on this.
Whether a particular ADC chip can handle negative voltages is not a function of the method it uses internally to do the conversion: it is a function of the voltage range of the chip itself. There are a number of SAR and flash ADCs that are designed to work with inputs that swing below digital ground, and there are a number of sigma-delta ADCs (mostly the ones that come attached to microprocessors and less expensive audio ones) with inputs that are constrained to not go below 0V.
Look at data sheets. If you get onto the websites of the major semiconductor companies (TI and Analog Devices spring to mind) you should find selection guides that list, among other things, the chips' input voltage ranges.
go.
on this.
Sure. Simple.
In the case of the SAR, you simply need a bipolar DAC with the
appropriate encoding in the feedback of the comparator. The sign bit
is the MSB (tested first).
A flash ADC would simply have the resistor chain between +2.5V and
-2.5V, with the comparators tapped off it. The output will be a
"thermometer code" but it's not a huge deal to convert that to
whatever code you want (same problem as unipolar, really).
Good Lord, you're an asshole, Fields.
Yes, really. Any second-year student would have studied this sort of
thing.
How would you convert, say, a 256 level thermometer code to binary?
A CPLD, if I had an idiot boss who asked for such a dumb thing. IT's
a simple matter of logic. Maybe more than one would want to hand wire
with 555s (all you know how to use), but simple nonetheless. The
trivial solution is 250ish 2in muxes; a trivial CPLD or FPGA exercise.
Kinda a dumb problem though. Not surprising coming from you.
mike
go.
on this.
First thing is to specify the problem.
"audio signal" is way to vague.
If you really mean "audio signal"
couple it with a capacitor sufficient to
pass the lowest frequencies and be done with it.
Even if you did build some kind of DC level shifter,
you still have the problem of deciding where zero is.
The solution is easier if you know what you're
solving.
mike
Which he did, and rather well.
He specified the amplitude, and "audio" is generally regarded as being
the range of frequencies which humans can detect aurally, so what's
missing?
Well, we now know what YOU mean by audio.
That may or may not be what the OP means by audio.
I've seen many an engineer lead himself astray with the words
"generally regarded". Why not just ASK for actual data?
Well, I'd start with a cap and two resistors.
But that's just me.
With the input signal varying from +2.5V to -2.5V, zero (0V) would be
where the polarity of the signal changes.
With the output signal being in phase with the input signal, the
output's zero (0V) would be where the input signal was at -5V and,
with unity gain, would vary from 0V to +5V.
Unless you're the OP, YOUR edification is not what's required here.
Last thing we need is to jump to conclusion and apply tunnel vision.
If your problem definition is correct, your solution is overkill.
U
Uwe Hercksen
missing?
Hello,
audio may be the range from 300 Hz to 3,4 kHz, or from 20 Hz to 16 kHz,
or 10 Hz to 20 kHz. It depends on telephone voice only or music and the
desired quality.
Bye
Syd Rumpo
Yes, of course.
However, since the OP's post was asking for help on how to convert a
bipolar audio signal into a format suitable for the signal input to a
monopolar ADC, the lowpass filter does nothing but attenuate the high
frequency end of the band, with the signal still remaining bipolar, so
no help there.
Probably Mike means a high-pass, with a resistive divider to set the
mid-point. R1 +Vref to Ain, R2 Ain to -Vref (which may well be Agnd)
and C1 fron signal to Ain. R1 = R2 with C1 and R1//R2 setting the LF
rolloff. Don't forget the ADC input impedance if it's unbuffered.
Cheers
mike
Did you just say that the question is unimportant because you have the
answer?
I know a number of product development teams that would be delighted to
hire that talent.
Yes, of course.
no help there.
Certainly not, since my understanding of the OP's wish list is crystal
clear and the solution I offered is viable and, being inexpensive in
its implementation, eminently practical.
_Your_ edification is what I was referring to, since you seem not to
have grasped the OP's meaning.
When a problem is well-defined, as was the OP's, then there's no jump
to a conclusion, there's just a methodology leading to the solution of
the problem.
That you don't seem to possess the skills required to understand the
problem, or to solve it, does not reflect badly on me.
Nonsense, but just on the off chance that you're right, how would you
do it?
BTW, did you run the sim?
You post a lot here. My conclusion is that you're a smart guy and this
is just an exercise in being contrary. You're going way out of your way
to be dense.
There aren't many ways to hook three components together to level-shift an
AC signal. You could have tried them all in less time than it took you
to bitch at me.
The more you know about the requirements, the better chance you have to
create an optimal solution. Being a hammer can be good...unless you
mistake a finger nail for a carpentry nail.
Ability to run a sim has value.
Knowing what to sim...priceless.
I answered the question, moron. All of this stuff is on the web if
you know how to look for it. I gave a *lot* more information than you
have. A level shifter (LOL). A typical Fields hack.
You were the one who put parameters on the project that made it a dumb
solution. He asked if it could be done. Certainly it can. Question
asked and answered.
Especially since most, if not all, flash ADCs have the decoder
on-board and present only the 8 data bits - instead of the comparator
outputs - to the outside world.
But that wasn't the question asked, dumbshit.
Is the one trick pony getting sensitive to the truth?
I posted a simple dual op-amp solution for his problem which one would
think even you should be able to understand.
A *really* dumb solution that no one doing this stuff professionally
would have dared offer.
Well... Maybe.
You really are proud of your Fields' hairballs, aren't you?
Because it's *much* easier to do a web search, given the right
keywords. It took me less than 30 seconds. Here, I know you're a
hacker, so maybe you can learn something (doubtful).
http://www.es.isy.liu.se/staff/alumni/eriks/tmp/NORCHIP_2005B_rev2.pdfo
P E Schoen
wrote in message
Could some electronics guru please shed some light on this ? First of all,
may I point out that my work so far has involved either pure analog or
pure digital circuits, with hardly any analog-digital conversion or
vice-versa. So my questions might sound silly to some experts. Here we go.
Suppose I am sampling an audio signal, whose raw voltage levels range from
+2.5 Volts to -2.5 Volts. I understand that a sigma-delta encoder could
tackle this, but can a flash ADC or successive approximation ADC tackle
Thanks in advance for your comments/thoughts on this.
If your source impedance is very low (such as the output of an op-amp), it
is fairly easy to shift the level with two equal value precision resistors,
one of which goes to the Vref. For instance, I'm using a 5V PIC with a 2.5
VDC reference, so when the signal is zero, the ADC sees 2.5/2 = 1.25V. At
the extremes of +/- 2.5V, the ADC sees 2.5V to 0V. Just make sure the
resistors present an impedance low enough for the ADC sampling to acquire a
solid reading. A small capacitor helps. I use two 3.01k resistors and a 10
nF capacitor which is good for most audio signals (I'm reading 60 Hz).
It is easy to convert the resulting 10 bit unsigned digital result to a
signed result by subtracting 512 counts. I use this for an instrument that
calibrates to at least 0.25% which is about the limit of a 10 bit signed
integer value.
Paul
Only because you cannot read. ...or understand.
"than you did" is the correct form, considering tense, and so you did.
But you offered more misinformation than information the OP could
actually use.
Another Fields' lie. BTW, how's your twin, DimBulb?
That's all he was asking for, and there's even a simpler solution than
the one I posted.
care to take a stab at it?
Level shifter? The whole concept is a hack, here. Where is "zero",
moron?
Another Fields' lie. Keep going...
Of course the simplest solution is just a bipolar ADC with a +/- 2.5V
input range and a sign bit output, But you sent him, in the first
case, on a search for a bipolar DAC, around which he'd build the ADC
with a SAR and a comparator. In the second case you sent him
scurrying for a flash ADC with a thermometer code output which could
"easily" convert to binary, both ludicrous.
That wasn't the question asked. But you don't care. You're only here
to prove how "smart" you are. Really, all you do is show what a hack
you are by publishing your Fields brand of hairballs. What a loser.
Actually, I did. Because you can't read, it's no surprise you don't
get it.
Yes. The truth is not an ad hominem. It's the truth. Sorry if it
hurts your sensitive ego.
Of course you would. It's obvious that you're not an engineer.
Question answered.
Why am I not surprised?
Simple. Because you can't read.
Obviously you don't understand the article. It *is* trivial. A
little hierarchy and it's a coupe of minutes work.
Jasen Betts
go.
on this.
if 0V is of special signifigance you may need an input of 0V
or use a bipolar ADC.
josephkk
moron?
get it.
Question answered.
Keith, if you were much of a human you would be ashamed to have posted
nearly pure ad hominems. Have fun with the strawman.
