Platforms
Content
I want to electrically isolate or disconnect power to a device when the sensor has reached the 2.0VDC alarm state.
What type of equipment is necessary to perform this action?
what is the sensor ... link ??
what is the device to be switched off and what voltage/ current is it using ?
How are we to interpret this sentence? If it take it literally, the sensor will output only one of the those three voltages, with nothing in between. But I suspect that it actually can output anything within the range and probably outside the range of 0.5 to 2V. Which is correct?I have a sensor device that has 3 outputs: 0.5VDC (warm up), 1.0VDC (normal), 2.0VDC (alarm state).
You should take the sentence literally. The sensor device has a dedicated circuit board with embedded signal processing algorithm. The output from the circuit board is arranged so that the voltage is delivered as a step-wise function (0.5V, 1.0V, 2.0V)How are we to interpret this sentence? If it take it literally, the sensor will output only one of the those three voltages, with nothing in between. But I suspect that it actually can output anything within the range and probably outside the range of 0.5 to 2V. Which is correct?
Bob
120A? Really? Is the load purely resistive?
And about those voltage levels. What do you want to happen when the voltage is very near a limit, so what happens when the voltage is randomly varying between 1.999 and 2.001 volts?
