Hi All
I have purchased a simple 12V DC pump. Model FA-1418 Max 5A. The motor is fitted with a 100 PSI pressure switch.
I would like to be able to control the speed of the motor and therefore the amount of water pressure produced upto the 100PSI max.
The motor has two wires leading to it, positive and negative supply.
Is there a way I can do this as ultimately I would like to control the motors pressure with a PICAXE chip.
Any advice or hints at what I need to get would be appreciated. I have used controllers for brushless motors and they can be controlled by a Picaxe, is there something similar for a motor like this or what problems will I encounter?
Thanks for your help.
