Natalie Bounds
1. When I started the heater and low power jets and filter it draws about
24.5-25 amps off
of a 30 amp 240 breaker set up. After about 3 to 5 minutes breaker trips one
side of 30 amp breaker.
2 As yesterday I went to add extra tablets to the floater in the water got a
shock from surface water
so what I did was go inside and flip on one side the 30 amp breaker at a
time.
3, What I got was the side of the breaker that kept tripping when switched
on had no voltage across
surface water. Then I turned that breaker off and turned on the other
breaker that does not trip and
a surface voltage of about 20 volts is what I got when tested to Ground.
The question is this breaker defective and need replacing/ I tend to think
so.
P.S. I have used this hot tub several times with no surface voltage.
24.5-25 amps off
time.
so.
