Hi all. I need to design something that will allow a piece of equipment to run on one battery then once that batterie's terminal voltage has dropped to a specific point (indicating eminent discharge), auto switch to another (fully charged battery) meaning the discharged one can now be swapped out for a replacement charged unit. There would need to be a visible indicator showing which battery has to be swapped out.
The device is 12V but can draw maximum high as 5.8A say 6A around 70W. I don't really want to use mechanical relays because the environment can be quite rough. The batteries are Li-ion 14.V 6.0Ah, 87Wh units, the equipment well able to tolerate the few volts over 12V.
My research so far I assume some kind of MOSFET will let me switch such currents such as the 'Power Trench" devices from Fairchild (FDS6612A)...
Obviously the circuit needs to be fairly efficient (pointless if it was to use more energy than the device being powered by the battery).
I could simply go for a 'Smart' power source selector Dual-Battery i.c. as in the MAX1538 (as i have found doing a Goggle) but my concern is that the circuit could never be 'patched up' in the field if it was ever to become damaged...
Of course if i use a bunch of op-amps to sense Vterminal and others to act as comparators , while effectively having the batteries in parallel for their combined and a visible alarm to show the one that needs to be replaced, switching it out of circuit etc then its hardly going to be all that efficient... Maybe an Arduino, maybe a Raspberry Pi?
Interesting quandary.... What do others think...
