Chuck Tribolet said:
Usually they come with a wiring harness. The hard part is figuring out
which wire to attach to which.
Your correct and I was thinking of a different model VHF.
I check mine when I was on the boat and found that I did have a DIN plug
with a couple feet of cable. Other end was 'raw'. Since that wasn't long
enough to reach my GPS (hub), I wired it into a terminal strip and then ran
two conductor wire to the hub.
This DIN plug also had the remote speaker, hailer and something else, I
don't remember. (And it's only been 6 weeks since I installed it.)
Steve
s/v Good Intentions
