My Honeywell security panel is working but it is not logging events
Platforms
Content
If you put it "15", then you didn't follow my instructions; which were to "enter #15, three key presses." That's #15, "Pound key, one key, three key" = pound-one-five, three keys to press. Sorry I didn't make that more clear.
The # symbol is sometimes called "pound", "number", "hash", or "hashtag". Its proper name is octothorp, but I never use that word because nobody else does either. In the alarm industry, referring to keypad entries, I've always heard it referred to as "pound", so that's the jargon I follow so the maximum number of people will understand what I'm saying.
I think I did give wrong information in thinking Field *90 displayed two digits--it's more likely one digit, which is the hexadecimal sum of what you choose to be logged. An entry of 15 (which requires you to press #15) will display as [F], hexadecimal for 15. I also neglected to tell you to press * after the entry, which you would have done if you pressed *99 to exit; but it's a good idea to check Field *90 before moving on.
In my defense, it was late and I was coming down with whatever is keeping me down coughing, sneezing and my nose running today. (I'm a sick puppy). :-(
Get back into programming, go to *90, enter #15 (pound-one-five) and then * (star) to save the entry. Then press #90 to have the panel display what is now in Field *90. I think it will be an F, but honestly I haven't done this in years--just don't have that much occasion to change that particular field.
Press *99 to exit programming, and check your logging again. If there's still a problem, I'll drag out my V-20P panel and hook it up and go over it myself to make sure I'm not leaving something out.
The "bell failure" is a separate issue. There's no way changing *90 will affect your bell or siren. I've been assuming you were working with a home system here, but you didn't actually say so. Most home systems have a siren or two rather than a bell.
What sequence of events leads you to say you have a bell failure? Please remember, I can't assume anything here: My only information comes from you. Telling me you "have a bell failure" doesn't tell me what happened/didn't happen, or in what sequence.
