Peter
I've had a lot of these pack up. Honeywell were at one stage blaming
it on RF pickup on the input cable, so I did some tests, connecting
into the cable and checking that no noise is present.
However, superimposed onto the DC control signal (-10V to +10V or so)
I saw a sinewave ripple, around 500Hz IIRC. The amplitude was only
about 100mV P-P.
I have the full schematics of the KFC225 computer unit and it is
evident where this ripple comes from: there is a lowpass filter on the
output, which converts a PWM waveform into the servo control voltage.
This filter allows a little bit of the PWM signal to feed through.
The question is whether this is intentional, whether e.g. the servo
uses the presence of this ripple as a confirmation that the computer
unit is still (partially) functioning. It would be quite a clever
trick, but it does mean that it isn't possible to fit a good filter
onto the servo input.
I have been quite unable to obtain the schematics of the KFC225 servos
- they appear to be closely guarded The amazing thing is that they
pack up so often... I mean how long have people been making little
boxes with a $50 Portescap servo motor, a gearbox, and a PCB with a
few chips and a few MOSFETs on it??
Peter.
about 100mV P-P.
Peter.
