Okay, just to be sure we're speaking the same language----there's nothing wrong with calling a 6280 Touchscreen a "keypad" in normal non-technical conversation, but among alarm techs, we make the distinction between Touchscreens (a.k.a. Touchpads, where "keys" are virtual and pressed on a screen) and Keypads (where keys are physical). We make the distinction because Touchscreens behave differently and are treated differently than Keypads.
The other day I disconnected my motion sensor at the panel because I could not fix the fault that the 6280 keypad kept displaying.
We can get back to that problem if you want to, after we handle the issue with your Touchpads. There's probably some simple reason the motion sensor's zone kept Faulting/stayed Faulted.
Then the keypads kept displaying "open ckt".
When a Touchpad/Keypad displays "Open Ckt", it means that it isn't seeing data flow from/to the Panel, nearly always because one of the data wires is loose. I'm going to assume that you have a Vista-15P, Vista-20P, or Vista-21iP Control Panel because those are the most likely Panels to find in a home; in which case, the data wires are connected at Panel Terminals 6 &7 (T6 & T7). Those terminals tend to get over loaded with too many wires under one screw terminal, because so many peripheral devices (Keypads, Touchpads, RF Receiver, Zone Expander, etc) get connected there.
If you have some other Panel than one of the ones I named, this would be the time to mention it.
(When posting for help on a DIY forum, it's ALWAYS a good idea to name the model of your Control Panel, as well as your Touch Pad/Screen.)
Back to T6 & T7, you may have had a loosely connected wire for a Touch/Key Pad and brushed it loose when you were disconnecting the motion sensor. I assume you disconnected power from the motion at Terminals 4 & 5. Look at T6 & T7 and tug on each individual wire to be sure it's connected solidly. Don't just pull on the wire bunch; a loose wire can hide in a bunch, and this is a common problem. You don't have to pull like a gorilla, just give each wire a firm tug to make sure it's not loose.
While you're at it, check the wires on Terminals 4 & 5 too---they also tend to be crowded and should be checked for loose wires hiding in the bunches.
Saturday we had an outage caused by TP Barry. Two of my 3 keypads went blank. As though there was no power. Checked the panel. Saw no problem. Last night I reconnected the motion sensor and everything was fine, except, now the keypads display "panel busy programming ". As of this morning they still display such. Is there anything I can do?
Here's where we get to one of the main differences between Touchpads and Keypads: Touchpads are power hogs! They're stylish and cool to use---but they're power hogs. The two Keypads commonly used with Vista Panels, 6150 & 6160, each draw 40 mA current in standby and 70 mA (6150) and 150 mA (6160) in alarm with display lighted and sounder going. Each 6280 draws 140 mA in standby and a whopping 350 mA in alarm state.
Your Control Panel's T4 & T5 provides a 12VDC aux. power output for peripheral devices (Keypads, RF Receivers [for wireless devices], motion and glass break sensors, etc, etc) that is limited to 600 mA continual draw. That's usually sufficient for most homes because most peripheral devices typically draw from 25 to 40 mA.
But when you add a Touchscreen, the system almost always has to have an independent power supply to keep it powered, which entails a separate transformer (usually 16.5VAC, 40VA) to power the power supply, and a separate battery. It sounds a lot like your independent power supply's battery has gone weak/dead. A dead battery drawing down the PS will cause unpredictable results--- look for an independent Power Supply in or near the Control Panel. Both Panel and independent Power Supply batteries should be changed every 3 to 5 years. Longer than that and they're living on borrowed time.
Chances are that your blank Touchpads were powered from the independent PS and the Touch/Key pad that still worked was powered from T4 &T5 of the Vista Panel. For the perpetually programming TPs, if you haven't already done this, power down the system---including the independent power supply---by unplugging, first batteries; then transformers, wait 30 seconds, and then plugging back in: Transformers first then batteries. Give the TPs a few minutes to settle out. (Another big difference between TPs and KPs).
Question: Do you have a physical-button Keypad in your system, or only Touchpads? I strongly recommend having at least one Keypad integrated in the system.
