Robert Scott
I have seen various postings about doing SMD prototyping with very
fine point irons and solder wick for cleanup, but I would like to try
hot air. But I don’t want to invest in a several $k professional hot
air SMD rework station. I just want to stick down a few SOIC-8
packages. I occurred to me that something like a heat gun might work
if the air flow rate were drastically reduced and the heating element
power were controlled down to an level to produce 700 degree F air,
and if a nozzle could be designed that squired out air in a little
slit. In fact, forget about the heat gun. Just consider a length of
nichrome wire, a controlled current, and a tiny fan. Has anyone tried
to make their own SMD hot air tool for experimental use?
-Robert Scott
Ypsilanti, Michigan
-Robert Scott
Ypsilanti, Michigan
