I don't own a noid light, but I had an old LED flashlight.
I have read that I can use an LED bulb and a resistor to make a noid light for testing the fuel injector system on a vehicle
I have a fairly good amount of experience soldering, from repairing wires and connectors on small electronics and wiring harness.
I know the resistor needs to go to the positive side of the bulb.
The bulb I have is 1.5V 0.2W , what would be the proper size resistor to use?
Did a little more research and it looks like most LEDs use around 20ma or 0.020 amps so is this correct:
13v / 0.020 amps = 650 ohm resistor?
is there anything else I need to consider?
One thing I was thinking is I could use a diode on the negative side to make sure if somebody accidently hooks it up with reverse polarity they dont fry the bulb, what size diode should I use?
