I am interested in building an inverter type power supply that will be used to power a homemade plasma cutter, i always have been really into electronics and welding/metal working, so i figured id try to go about building my own equipment, i have build a welder in the past by rewinding the secondaries on microwave transformers, i want to try something new, i want to build a plasma cutter using an inverter powersupply, which is what i need help with.
Not sure if i want to use 120v mains or 240v mains yet, but the power supply will need to output about 200 volts (open circuit) at around 40 amps, will be later developed to have variable current output.
I understand the basics of how an inverter power supply works, i plan to use an AVR to provied the PWM signal to drive the IGBT module. i understand that that basically an inverter supply takes the mains, rectifies and filters them, feeds them through the IGBT module which is driven by the PWM of the microcontroller, and fed through a transformer, rectified and filtered again, i am just clueless on where to start with designing one to fit my needs, what components determine the output power? how do i design the transformer?this is where i need help
