Joe.G said:
Hi All,
I have a spec analyser and I looking for suggestions
on antennas and comb generators within an afordable budget..
I have seen some scanner antenna's that are log periodic that have a wide
bandwidth.
The main goal is to get some idea if my product is
radiatating somewhere near the EMC limits or not.
Thanks in advance.
Joseph
Andy writes:
For frequencies that can be built with a patch antenna, the
following procedure can be done:
1) Connect a signal generator to a patch antenna (for each frequency
to be calibrated, which points UPWARD to the cosmos.
2) Suspend a dippole antenna 20 or 30 wavelengths above the patch.(
Not
a problem above , say, 500 mhz).... (minimal reflections this way)
3) The antenna should be a SMALL dipole, much shorter than a quarter
wave at the lowest freq.
4) Develop a calibration curve for this antenna.
5) When making any measurements , then, at these frequencies, you
must allow
for reflections, depending on your measurement facility. This
procedure
is well established in literature for "open field antenna
measurements".
To simplify this summary:
It is not possible to do this in a simple manner. Antenna field
measurements are extremely complicated by reflections, absorption, and
inaccuracy in the transmitted field. If you buy a CALIBRATED field
strength meter, and attempt to make measurements, you may find up to
20-30 db field strength difference base on 2 or 3 feet of field
strength
meter movement...... this is a bear....
If you have a calibrated large room lined with 400 Mhz ECCOSORB, you
would have not asked ( big grin).
At lower frequencies ... well, you just do the best you can. The
near field curvature will kill you and reflections may bury you....
If you just want to build a ball park value, just put a signal
generator
into a dipole, and mount the pickup antenn 3-4 wavelengths away, and
raise
and lower it a half wavelength or so to see the range in values. This
ain't bad for ball park figures.....
Sorry,.... but that is why EMC engineering is such a definite
specialty.....
Andy , retired NARTE Licensed EMC engineer
