I found (on web searches) reference to motor "run" capacitors and motor "start" capacitors. Don't know which I need. In the base of the fan, directly from wall cord, this capacitor was removed: MP CON. 2uF 230V.AC (Hitachi logo mark) 808 or 8D8 (looks like "8D8" to me). I live in Japan, but the "home centers" here don't stock electronic parts (& no electronic supply stores in the countryside where I live) and when the home center called Hitachi repair service, the maker claims that the fan is too old and no repair parts are available anymore (of course, the purpose of that is to sell new fans at high price). I replaced a capacitor in a Japanese fan before (someone was throwing the whole fan away as it would only hum, or the fan blades "almost imperceptively" moved slightly when power was switched on). After the capacitor replacement it ran robustly with zero trouble for 3 years and I gave it away to someone later who is probably still using it to this day. So, I thought capacitor replacement would be easy, until I found out the variety that is out there, when searching Amazon's Japan web site. Also, I wonder if replacing the 230V with a 250V would be alright (asssuming I keep the 2uF the same). I found a "ceiling fan" capacitor on US side Amazon and wonder if it might work. It is newer style, black square block, but is rated at 2uf 250V. several others are rated at 2uF 450V. So, Q1: Start or Run capacitor, which is needed?; Q2: If 2uF is kept the same, is 250V or 450V wrokable (and safe) as a replacement? Thank you for your help.
Platforms
Content
