Hitachi 27AX2B dead set NO relay click
drradio1
We have an Hitachi 27AX2B that is dead NO relay click.. we have 160
volts from the regulator to the output transformer, the ON/OFF switch
is OK.. Any ideas would be appreciated
What are the results of standard troubleshooting? What are the standby
voltages? Do all the buttons and ir sensor work properly? What does
the system control attempt to do when the power on is pushed? What is
the sequence of operation in the tv by the system control for turn on?
Standard troubleshooting should narrow the problem down.
Art
General in-depth diagnostics may be helpful to locate the cause, if not sure
how to proceed then take the set to a qualified service facility.
