I am using a Hioki 3540 tester to measure resistance across 18 AWG copper wires. To verify that the tester works fine I measured known resistances ranging from 10 ohm to 300 ohm and it seems to work fine. But when I measured the resistance across my circuit (which has two relays) then I seem to have trouble reading values accurately. The issue I see is wide fluctuation of the resistance values in the display screen ranging from 0 ohm to OL and this keeps cycling. I verified the contacts of the relays and there seems to be no issues and also I verified continuity across the entire circuit, seems to have no issues. But why is the hioki tester reading such a wide fluctuation of values? Need help.
Platforms
Content
