Rock said:
I'm working on a high voltage power supply of about 9KV. I'm using a
transformer that gets me up to about 1KV and then stages of capacitor
diode voltage doublers.
I'd like to be able to do some kind of regulation of this supply,
however just the cost and space for a high voltage (1 billion ohm)
divider makes it a no go. This supply drives a capacitive load with no
current flow (normally).
Any one of you super smart engineers have any ideas? Like a magic part
that can sense field strength with no current flow? Wonder if I could
get a mosfet to work with just an air gap from gate to the HV?
Thanks!
Rocky Lavine
Rocky Test
I bought a couple of electrostatic voltmeters - they are just like in the
textbooks, constructed much like an air spaced variable capacitor, but with
very low friction bearings, and balanced. They aren't much good for
feedback though, except manual feedback if you adjust the input power
yourself. They still seem to have some more of those:
http://www.stewart-of-reading.co.uk/sor_misc.html
If the power supply were only required to be stable for seconds or perhaps
minutes then you might be able to make a capacitive divider, but any
leakage resistance would cause it to drift.
If you make a grounded motor-driven rotating metal disc with a hole in it,
and spin this disc between your high-voltage circuit and a small plate of
metal connected to a virtual earth in an op-amp current-to-voltage circuit,
then this ought to produce an AC output proportional to the electrostatic
field. It's a pity about the rotating parts though. A hard drive motor
should last a long time, but it uses a fair bit of power and makes a noise.
Inside the flyback transformer from a TV, there is usually a very high
resistance potential divider for the focus electrode, I am trying to figure
out how to use that to measure the EHT output on my high voltage supply,
since I am using the flyback anyway so the divider is free, and it can
handle the voltage. Maybe this would suit your needs too. The tap for the
focus electrode itself is at too high a voltage to be much use to me unless
I connect the wiper to a "low value" (1M?) resistor to ground, however I
think this might increase the stress on the upper portion of the resistor
string so I'd prefer to avoid that. If I can get at the bottom end of the
resistive divider (separately from the return path of the windings in the
flyback) and put a lowish resistor in series with that then I might have a
solution.
Chris
