High voltage electrolytic capacitor availability for old tube amp.
I have replaced filters in this old Bogen tube amp once and it just
came back after four months with the new ones leaky again. The new ones
were old stock but just to be on the safe side, I did "form" them
before I put them in and they seeemd OK. The B+ off the 5AR4 is 425
volts. I used 30 MFD. 450 volt caps and monitored amplifier warm up and
didn't notice any surge before the rest of the tubes warmed up so I
figured I was all set. Now I'm thinking that I should be using perhaps
475 or even 500WV caps, but can you still even get these that would not
be old stock and possibly worse that the ones in there now? I could
drop the B+ but I would rather not do that unless I really have to.
Thanks, Lenny Stein, Barlen Electronics.
K
Ken Weitzel
http://www.justradios.com/capacitors.html
G
g. beat
CDE / Mallory still makes capacitors in the Carolinas.
Large on-line database catalog
http://www.cde.com/
You can go to 550 volts with the DCMC and 500C series (CDE)
and 500 volt with 520c, 550c, 380l/lx AND 382l/lx series
http://www.cde.com/alumframe.htm
You may want to look at a long load life, if this is a continuous duty
application.
for Mallory models - CGH goes to 500 V
http://www.cde.com/maecframe.htm
CDE were selling on-line small orders,
but distributors complained -
SO the deal is -- your distributor CAN NOT turn down your request -
regardless of quantity.
Mouser is very good in getting these items for you.
gb
