How can I test these kind of capacitors in any circuit?Is it at all possible as some suggested to test them with a Insulation Tester/ Megger ? Some Old valve repair tinkerers use a megger for older paper Capacitors.If a person charges the cap to 4000Vdc with a Insulation Tester then read off the resistance and calculate leakage current,would that at least give a indication whether the cap is useable?OR give some advise on how to test them.Thank you.
Platforms
Content
