Dirk Bruere at NeoPax
How are batwing high power LEDs attached to heatsinks?
Are they soldering iron solderable or is it an oven job?they generally get soldered to aluminum substrate PCBs,which then are
bolted to larger heatsinks.
for examples;
http://www.theledlight.com/LuxeonLEDs.html
you can buy the aluminum substrates from Deal Extreme.(Hong Kong)
Jim Yanik said:they generally get soldered to aluminum substrate PCBs,which then are
for examples;
Is there something wrong with (standard) copper?
On standard board most of the thickness is fibreglass. On aluminium
board the insulator layer is thin and most of the thickness is the
aluminium. Vastly better heat transfer from front to back of the
board.
How about sticky backed copper foil on a Al heatsink?
G said:I use thermal epoxy. Gets tricky IF the LED is not isolated. Easy
if it is. For insulation I used diamond dust.
Robert Baer said:Bonding via flow soldering?
I haven't figured out how to do that easily. Maybe the board could be
soldered to a plate with high temperature solder then the LEDs applied
to the board with low temperature solder. I don't know if high temp
solder remains strong enough for that to work without the PCB popping
off and scattering $150 of LEDs all over the place. Another option may
be creating a silicone slab that could press the hot PCB down without
touching the LEDs. It would require some testing to see how big those
holes need to be to allow for thermal distortion. A grid of screws
won't work because they will interfere with surface mount lenses.
I still think etching aluminum-clad PCB would be easier for personal
projects.
Dirk Bruere at NeoPax said:Alternatives:
a) Built in heatsink - anyone do a basic, cheap, range of deep red LEDs
3W+ with its own heatsink eg TO3
b) Heatsink compound with some kind of mechanical fixture to a standard
heatsink
