Paul E. Schoen
I am planning to make a circuit to convert 12 VDC or 24 VDC (and possibly
48 VDC) battery power to 360 VDC or 720 VDC to drive the DC link of a three
phase VF motor controller. I'm sure it could be done with high frequency
(20 kHz-200 kHz) magnetics, but I would like to try a somewhat lower
frequency. Here is my plan:
I will use a nominal 1 kVA (60 Hz) toroid core, and remove the 120/240 VAC
windings. I estimate about 0.4 volts per turn. I will drive the transformer
with 600 Hz, so that would be about 4 volts per turn. If I use a center tap
push pull driver on 24 VDC, I think about 8 turns on each leg would be
about right. For 10 kW, I would need close to 400 amps at 24 VDC. I'll use
#10 AWG wire with about 8 in parallel for 50 amps each. For the secondary I
will try 160 turns of #14 for 20 amps at 480 VAC, into a full wave bridge
and capacitors for 720 VDC. If I run it on 12 VDC I should get 360 VDC for
the 240 VAC VF controller.
Now, for the drive, I will try using a PIC or an SG3526 to generate a
simple square wave with some dead time. I may add a capacitor across the
primary to reduce high voltage switching spikes. The current sinking
components will be power MOSFETs. I may use IRL2203N (30 V, 100 A) for my
initial prototype (which will be just 0.75 kW and 12 VDC). For this I
figure about 60 amps input, shared by the two MOSFETs. At an ON resistance
of 0.007 ohms, the power should be about 25 watts. For my final product, I
will use something like STP140NF55, and about four in parallel. They are 55
V, 80 A, and 0.005 ohm. Not bad for $1.56 each. What I will have is a
battery powered three phase 15 HP motor controller.
What I am unsure about is high voltage spikes and high current surges
resulting from using a square wave on the transformer. I tried modeling
this using Tina, and it seemed to be OK, but it helped to add a capacitor
across the transformer primary and some inductors in series with the legs.
I know that uncontrolled transients with this much power can quickly turn
quite ugly, so I want to be sure everything will be OK.
Any insight and comments will be appreciated. Thanks.
Paul E. Schoen
www.pstech-inc.com
Paul E. Schoen
www.pstech-inc.com
