Richard Rasker
Hi all,
I regularly repair tube amplifiers, and there's one thing I occasionally
encounter that doesn't appear to make much sense: a high resistor (> 100K)
in series with one of the first 12AX7 preamp tube grids.
OK, I fully understand that this resistor, together with the Miller
capacitance between grid and anode, can act as a high cut-off filter, and
that this can prevent HF oscillations and the likes, but it also introduces
noise -- a LOT of noise.
I have here exhibit A, a Peavey 5150 EVH. Shorting the aforementioned 470K
grid resistor in the second preamp triode cut the noise level by as much as
15dB(!). OK, the sound got slightly more agressive as well -- definitely
more treble in clean mode -- but that didn't matter too much in overdrive
mode (and in clean mode, just small adjustment of the Treble control would
take care of that).
So my question is if anyone can explain why any designer would use such a
ludicrously high grid resistor -- IMHO, there are far better ways to create
a high cut-off circuit instead of this messy, noisy "solution". Or is there
some sort of extra or hidden advantage to this?
Thanks in advance, best regards,
Richard Rasker
take care of that).
Richard Rasker
