Hello,
Suppose i have a load of LED luminaires that i want to light from a power supply.
I can do it with a voltage source power supply, and have current regulators connected up to the voltage bus.....................OR
I can have a high frequency (50KHz) sinusoidal AC power CURRENT source, and simply couple the led luminaires to the power bus via current transformers.
The current source way means having completely waterproof connection.........as opposed to the voltage source way, where lots of non waterproof connectors would be used.
So, do you think this is a viable proposition?.......and if so, what steps would you take to assure a good power factor in the current source bus?
