high current unity gain buffer !!
Matrix
Hi all
i have a trapezoidal wave of about 150ns rise n fall times with DC
voltage built into it. i want to remove the DC from the signal and
buffer it or amplify little bit (say 1.4 or 1.5 gain) without being
distorted. i have two such lines with signals 180 deg out of phase.
when i feed these signals into xDSL line driver/Buffer LT1794
then one line is distorted very much while the other is affected
slightly. then i have to transmit these signals on a twisted pair
differential bus.
1. How to remove DC from the signal, simply adding a cap does not
symmetrically shift the wave about 0V line. (or x-axis).
1. Please someone guide me about how to buffer/amplify that trapezoidal
signal without being distorted for providing about 400 to 500mA current
as a maximum.
2. and then how to get connected to the bus to transmit for a short
period of time and then be disconnected for the rest of the time.
thanks a lot.
W
Winfield Hill
Matrix wrote...
differential bus.
You can inject currents into the LT1794's summing-junction nodes.
as a maximum.
Are you driving a transformer? DC currents could be a problem.
thanks a lot.
Will the LT1794's shutdown / disconnect capability suffice?
Or is the part's 10us off and 2us on delay too much?
Matrix
What do you mean by summing junction diodes ?? Do you mean the
conventional inputs (pins 3,4 & 7,8) and i should inject the current
instead of voltage !!
YES, i have to drive an isolation transformer before i could transmit
anything on the bus. What should i do to cater for the DC currents.
i am not shutting it down rather i have biased it permanently for 10mA
current.
Thanks.
