Hello Electronics Point
I have a new dilemma:
Fuse, I cant find a Resettable fuse which can hold around 55A and 60Vdc. I have looked at just putting some or these guys in parallel (http://www.mouser.com/ds/2/54/mfrx-48102.pdf) but although it decreases the resistance and makes it look very efficient, having 8 of these things in parallel just does not seem right, sort of non professional. I have thought of using P-channel fets to attempt to minimise the current (using discrete components). does anyone have any other good ideas on how to put some safety on this without going through a mC?
I should note as well, I have sensing the current via a sense resistor and going through am opamp into a mC, but this us to operate as a secondary failsafe in case something goes wrong.
Does anyone have any good ideas? cost is not massively critical however should be kept to a minimum (Ie, no more than a few £)
