high-capacity AAA NiMH batteries - who sells them?
BW
I was seeking some AAA batteries for a cordless phone, to extend the
talk time. The existing batteries
are 970 mAh, so I was hoping to get some 1300 mAh. Local shops don't
seem to stock anything over
1000 mAh. On fleabay, there are tons of Asian vendors offering 1300
mAh, but these are brands I never
heard of. Also, I saw two sellers with pictures of the same battery,
and one claimed it is 1300 mAh, but
the other seller lists it as only 1250 mAh. I start to wonder if any
of them are truly rated.
Has anybody found any AAA that really has the extra stamina?
Sylvia Else
Are you sure it's their capacity that's the issue and not their
self-discharge rate? How long are you leaving the phone between charges?
Sylvia.
terryc
talk time.
Try Jaycar.com.au.Caveat, not sure of exactly what they have.
BW
Sylvia.
Generally, I leave the phone on charger until it shows full charge.
Leaving it there full time will reduce the battery life, as it is not
a smart charger. Even when showing full charge, it only lasts 60
minutes (the trouble and strife can natter this long with any of
her gossiping friends). When she was away for a week, the battery took
about 5 days to go flat.
Sylvia Else
OK, so not a self-discharge issue. Sounds like a higher battery capacity
would simply result in longer conversations though.
1 hour seems a very short talk time. Maybe she's already trashed some of
the batteries by overdischarging them:
http://en.wikipedia.org/wiki/Nickel-metal_hydride_battery#Over-discharging
I looked around the net, as you have obviously done, but didn't find
high capacity cells from reputable suppliers either. There's clearly a
theoretical upper limit on the capacity of a cell of a given volume or
mass, and 1300mAh may be pushing it for an AAA.
Maybe it's time to look at a new phone instead? I brief search revealed
this page:
http://cordless-phones-review.toptenreviews.com/
Sylvia.
Sylvia Else
Maybe it's not the phone that is the problem or needs replacing ?!!
Replacing the phone is bound to be cheaper than replacing the wife.
Sylvia.
Sylvia Else
Thailand & the Philipines have some inexpensive models.
I was more thinking of the ongoing costs of getting rid of the old one.
Sylvia.
