Hi-precision voltage and current sensor
O
Ole Voss
where would I find something like this? I know National makes current
sensors, but where do I find a hi-precision voltage sensor?
Any suggestions greatly appreciated.
Ole.
O
Ole Voss
Ok, I think I was mentally absent when I posted the above ;-)
I presume a normal ADC will do the job?
Ole.
O
Ole Voss
Yes, to both.
;-) Agreed
Put a resistor in series with the voltage, and feed the difference
across the resistor into your ADC, and you've got a current sensor.
Just to refresh my non-existant skills: The resistor I'd be using to measure
the current should be extremly low, right?
Any hints where I'd find some good literature for "do-it-yourself"
Volt-/Currentmeters?
Regards,
Ole.
Mark (UK)
Hiya!
Yes, it depends on the current flowing in the circuit, and if you can
accept a small voltage loss.
Yours, Mark.
