Mike
Hello-Has anyone tried using a interior wood stove to heat water and pipe it
to anther room or building. I am trying to do this and having problems. I
am running a .75 hose (also 1/2 copper) line to a garage and back. total of
300 feet of hose. To heat the water I bought a coil of soft copper 5/8
tubing which I simply put inside the wood stove. I am having problems
getting hot enough temps from the tubing. Max seems to be about 40 degrees
Celsius. I insulated the buried lines with 1 inch of Styrofoam. The return
line and heating line are side by side in the insulation. I simply cut a
groove in strips of 2 inch insulation and trapped the line within two pieces
of the Styrofoam. I have two radiators from a hospital in the garage-each
being about 4 feet long. I have them connected in series. Total amount of
water is about 5 or 6 gallons. Questions:
Am I expecting too much?
Is it too little water to take the heat to the garage?
Should I build a tank and somehow fasten it to the wood stove instead of the
coil of pipe?
Any help would be greatly appreciated as I expected this to work a lot
better. A lot of people around here (Manitoba Canada) heat their entire
farm buildings using outside wood stoves but they have 1.25 buried pipe with
a lot more water.
Mike Annetts
coil of pipe?
a lot more water.
Mike Annetts
