I need a solution for a voltage regulator for a 28V DC starter generator.
I have a vehicle gas turbine from mid 60:ies that is equipped with a starter generator EEMCO 72121. I intend to put it in a boat and of course there are many problems to solve. This is one of them.
The voltage regulator has always been missing and now I need to find or build one. I have the starter relay.
The starter generator has 4 connection points and the start cables are connected to 2 of them.
I have a function description and scheme (attached) but the components are not specified. If you could help me by specifying the components I can build one myself but there might be other solutions out there that will do the job just as well.
Any help on the parts needed or hints to resources that will help me are very appreciated
Thank you
Thank you
