@David Stamper Ah! You are conditioning at least
three of those little puppies, and it looks like you want to insert the PCBs into a tube, perhaps along with some other electronics, and eventually produce a commercial product. Good job! In which case, the commercial instrumentation amplifiers are definitely the way to go as
@AnalogKid suggested. I thought you were perhaps in a university environment and learning how all this works rather than shooting for a product you can market.
I have been a fan of Burr-Brown and Texas Instruments since I first started using their products in the 1960s. When Burr-Brown was purchased by Texas Instruments for $7.6 billion in September 2000 things just got better. With the TI mother-ship support they have continued to excel in design and production of analog devices, which some pundits thought were a dying breed. They are still my "go to first" source, although there are others such as Analog Devices and Linear Technology. Analog design is far from dead. In fact it is thriving and now integrated with digital, as can be seen in TI's MSP430 and Microchip's PIC line of processors, just to give two examples.
As for op-amp selection (if you still want to go there), that's a whole 'nother ball game. I like the generic 741 in all its many variations (single, dual, and quad packages) because it is "bulletproof" and cheap, but it is very old technology, being the successor to the even more venerable Fairchild μA709 op-amp, which required external compensation to keep it from oscillating, and external trimming because its offset voltage which was terrible. Since the 741 was introduced, technology has gone on to offer FET inputs, CMOS, and chopper-stabilized op-amps, laser-trimmed offset compensation and power op-amps with dozens of amperes and hundreds of volts output capability. And that's just the tip of the iceberg of technology available today.
If you are new to op-amps, TI offers an
application note that will get you started. It's about a two megabyte download, so a bit large to upload here. A "pretty good" instrumentation amplifier is the Burr-Brown/Texas Instruments INA121, available in an SO-8 surface-mount package. You might want to start there. It does require a bi-polar power supply (as does the INA114 you linked to) but ±2.5 or ±5 V will work fine. You may need to use ±15 V supply to get a ±10 V output. See discussion below. Be sure you null the bridge output before applying the bridge signal to the amplifier.
with a gain setting of G = 1 + 50k/R1, R1 obviously being the bridge resistance,
I don't understand this. The gain-setting resistor has nothing to do with the bridge resistance. The bridge output is applied to the two high-impedance inputs and the bridge resistance has no effect on the instrumentation amplifier gain.
So in to finding this sweet spot we are looking for, mainly it requires first finding the max output of sensor at max pressure first, then designing amplifier based on those values which will later be used for the amplification. I imagine this set up will probably have to be different for the 15, 30, and 60 PSIA chips, so that will be in part the steps for today!
No, it requires you to know the
change is bridge output between the minimum and maximum pressures. It is this
change in signal you want to amplify, preferably
after removing whatever offset is present at the minimum pressure. Thus, you start with zero input to the instrumentation amplifier at minimum pressure (by nulling the output at that pressure) so the output of the amplifier will be zero for any gain (ideally) at that minimum pressure. Then you set the instrumentation amplifier gain to produce +5 V at your maximum pressure.
You would need to do this for each transducer because there are three different full-scale pressure ranges of 15, 30, and 60 PSIA, but all have 100 mV full-scale output at their rated pressure. In other words, each transducer will produce a 100 mV change in output (with 5 V excitation) from 0 PSIA to its rated pressure range of 15 or 30 or 60 PSIA. The "zero" for each transducer will be different for the same pressure applied to all three transducers because your "zero" pressure isn't 0 PSIA unless your are pulling a vacuum on your air bladder. It will instead be whatever minimum pressure you apply to the air bladder, and this minimum pressure will cause a different bridge output depending on the full-scale range of the transducer.
You could hope that the bridge output at minimum applied pressure is small enough that, when amplified by the instrumentation amplifier, there is still enough "head room" in the amplifier output to accommodate the bridge output at maximum applied pressure. I don't know what your minimum applied pressure is, but it is likely to be a significant fraction of the transducer's rated full-scale pressure, perhaps even atmospheric pressure if you don't pull a vacuum.
Let's say you are using the 15 PSIA transducer and are at atmospheric pressure for the minimum pressure. Since atmospheric pressure is about 14.7 PSIA, you are nearly at full-scale for this transducer, half of full-scale for the 30 PSIA transducer, and one third of full-scale for the 60 PSIA transducer. Without nulling any of the transducers the instrumentation amplifiers could be set at a gain of 50 to produce +5 V full-scale output for each transducer, but the 15 PSIA transducer would almost immediately reach its linear full-scale limit (but not its maximum safe pressure limit of 45 PSIA) when the gauge pressure increases from atmospheric pressure, 0 PSIG, to 0.3 PSIG. That's probably a useless measuring range. The 30 PSIA transducer will be at half of full-scale under the same conditions so the pressure can increase from atmospheric pressure, 0 PSIG, to 15 PSIG before it reaches full-scale, but then you are only using half of the linear range of the transducer. The 60 PSIA transducer will be at one-third of full-scale under the same conditions, so the pressure can increase from atmospheric pressure, 0 PSIG, to 45 PSIG before it reaches full-scale, and now you are using two-thirds of the transducer range.
Unless your applied pressure is less than atmospheric pressure (you pull a partial vacuum on the air bladder), you will always be limited to less than the full-scale range of the transducer without external offset nulling of the bridge. That's just the way an absolute pressure transducer rolls. Some designers will just accept this and compensate for it in the analog-to-digital conversion, subtracting out the offset in software. What you sacrifice is dynamic range in the measurement since the instrumentation amplifier gain must be small enough to accommodate the initial offset and not saturate (become non-linear) when full-scale output, plus the offset, from the bridge is applied.
Your product has an inherent and unpredictable maximum offset of ±35 mV at 0 PSIA input pressure, which is one third of the linear output range of 100 mV. It is impossible to know the magnitude and polarity of this offset without measuring it for each transducer, but you can set the amplifier gain to accommodate whatever it is without external nulling. For example, choose worst case of +35 mV offset that is not nulled externally. With a gain of 50, this produces an output of +1.75 volts from the instrumentation amplifier, leaving 3.75 volts of headroom for signal if the maximum output is limited to 5 volts. However, increasing the output capability to, say, ±10 V restores the headroom and allows the transducer's 100 mV full-scale change in output to produce 6.5 V at the output of the instrumentation amplifier. Voila! No external nulling required. You can now remove the high-level +1.75 V offset output by subtracting it from the instrumentation amplifier output using a simple op-amp summing circuit, or scale and digitize the output with an A/D converter, removing the offset in software. The latter is the approach I would take to minimize external components associated with the pressure transducer.
It would help if we knew what you are trying to do rather than how you plan to do it. For example, one transducer with 60 PSIA range may be sufficient to use without external nulling if a high-resolution A/D converter (22 or 23 bits delta-sigma converter comes to mind) is used at the instrumentation amplifier output. Non-linearity and offset can be easily removed with software.
Hop
BTW:
@AnalogKid knows what he's talking about. He's just less windy than I am.
![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
