Hello all, I need some advice please.
My solar kit:
An old 255watt, 30.2 volt, 8.43amp solar panel.
Batteries x3 MK AGM mobility M45-12 sld m, 12 volt 45ah :Max charge rate 13.5amps
Duel Charge controller PWM 20 amp LTD-D1220d. :Max input from solar 41volt, 260watt
Lets say that it's a blazing hot day and the old panel is working to it's max; will the charge controller pump out 8.43 or 20 amps? Am I right in thinking what ever amps it receives, it gives to the batteries (8.43a)?
I don't want to charge the batteries too quickly or be left with out power; I'll be running 12volt led lighting, laptops and a 12volt satellite tv receiver & 12volt computer screen.
Do you think I have enough batteries?
The problem that I have is two batteries have been used for a year, and the other is new. Which is why I got a duel channel controller. I intended to buy another battery of the same kind, but would it be best if I use the two old batteries on one channel, and buying a larger wet cell on the other?
My solar kit:
