I'm trying to fix an intake manifold runner control board from a Ford Focus ST170. The board is set up to take a -5V signal input and a 12V power input from the car's battery. The main components in the circuit are:
Here's a circuit diagram taken from the file I attached.
Input 1 is the -5V signal
Input 2 is the 12V power
Input 3 is the earth
Input 5 & 6 are a switch which is opened/closed when the cable is pulled, to tell the ECU that the valves have opened.
I'm using a pair of battery packs to get roughly those input voltages, -4.5V from 3 AA batteries and 11V from 3 AA batteries and a 9V battery. Each battery pack is connected to a common earth at 3. When testing each source individually, the voltages are correct at each point, however when both are on, the voltage at 2 drops to 2.5V, while 1 remains at -4.5V.
I've tested resistance across each of the D1 and D3, and both seem to be working, with high resistance in one direction and low resistance the other, when tested with a multimeter at the 200K setting. After many problems with components failing already, the board isn't looking very healthy, although it doesn't seem to be causing the problem. (I've replaced Tr2 three times and D1, due to faults, as well as IC1 and SMtr1 twice each while troubleshooting). I've checked that there isn't a short between any of the terminals on the transistors, the chip or the inputs, and they all appear to be correct.
Can anyone suggest components that may be at fault to cause this problem? So far I've replaced SMTr1 as I thought there may be a current leak from the base to the emitter, but that hasn't made a difference.
Thanks for any help!
- a transistor
- an IC (LM1949n injector driver)
- a darlington transistor
- and a motor
