Is this an engine with a float bowl carb? If so, remove the banjo bolt that
holds the bowl on and clean out the tiny passages in it, those clog easily.
The little white o-ring is the needle seal. It goes up in the needle
well.
If you look up in the needle well wth a flashlight you'll see the old
seal.(It'll be stained a yellow-brown color from the gas.)
Yo can pry it out with a small right angle dental pick or a slotted
jeweler's screwdriver. alternately you can also get it out by shooting
compressed air through the fuel supply inlet, should pop right out.
Press the new seal in using a dowel or punch the same diameter as the
seal. A bit of fine machine oil can be used to lubricate it to make it
slide in easier.. Be sure it seats firmly in place.
Test the needle to seat action before reassembling the carb to avoid
flooding out the mower.
You say it didn't last long. Did it just quit after running for awhile
or did it try to start and then die out?
The next thing that could be a problem is the primer bulb.
Depending on the model it could either of three different type priner
bulbs.(The carbuerator draws part of the suction required to pull gas
from the bowl through the primer bulb ports. If the bulb is rotten or
has a puncture it'll cause suction loss.)
A visual inspection on the bulb will usually tell. It'll be cracked or
split or be "gummy" when you squeeze it.
It's easy to replace and doesn't cost but 3-4 bucks.(Sears or parts
store.)
It'll be either the round non vented bulb, black, red or orange in
color or the accordian style that comes in either non-vented or
vented.( will have a small 1-2mm hole in the center of the bulb.)
All are held in by a circular spring clip. It has 5 or so square tabs
that stick out to grab the primer bulb well walls.
It can be prized out using a small slotted blade screwdriver, either a
#0 ot a narrow slot #1 blade.(jeweler's driver will work as well.)
Spray the whole spring and housing with a bit spray oil to slick it up
a bit.
Prize under one of the tabs until it moves out a bit then mover onto
the next one going a bit at a time in a circular pattern until you get
it out completely. The bulb can then be pulled or prized out. don't
worry about damaging it, it's a toss off item and can't be fixed.
Clean out the well with a bit of carb cleaner spray and a stiff
bristle brush, wire bruch is fine. You can also scrape out the old
rubber with a screwdriver or dental pick.
To install the new bulb just place the bulb all the way in and press
in the new retainer clip with a small slotted screwdriver.
This is done by placing the tip of the screwdriver into the circular
depression in the ring and pressing a gently at different points of
the ring in a circular pattern untill the ring is all the way against
the lip of the primer bulb. Then gently but firmly press with the
screwdriver in the depression of the ring at the base of each of the
retaining tabs.
You can test for a firm seat and lock by simply pinching the tip of
the primer bulb between forefinger and thumb and giving it a gentle
tug.
If it pulls out the tabs on the retaining ring have been overstressed
and need to be bent out straight.(Sometimes they come from the factory
out of spec and won't form a tight fit on your particular carb
housing.)
If the original ring came out in one piece and didn't snap you canuse
that one.
However to retension a spring, new or old, you use a pair of needle
nose pliers and gently bend the tabs out a bit so that they'll fit
snugly down the bullb well on your carb. Just be careful as it is easy
to snap the ring itself overstressing the tabs.
Also ensure that all of the fine ports on the carb are clean. This
includes the small hole on the lower side of the primary jet well.(The
well that the brass jet/bowl screw screws into.)
Also the brass bowl retaining screw depending on the model also has
one or two small ports on it that need to be clean for fuel to get to
the main supply port.
The short screw has one, the taller screws have two, 180 degrees
opposed at the base of the screw.(just under the hex head.)
You can use an aerosol carb spray to clean them out. I use either the
High-Tech brand from Wal-Mart, The store brand from Autozone or a good
name brand like Justice Brothers Carb spray. Anything that is acetone
base is good. Avoid Gumout carb spray, worst stuff made.
Most all come with a red plastic pipette for blasting out fine ports,
use it.
If the clog is stubborn spray some cleaner in a small cup and soak the
parts to soften the clog up.(I use the plastic cap that comes on the
spray can.)
If the ports won't unclog using the cleaner take a small piece of
stiff wire.( I use a piece of copper strand from a piece stranded
automotive wiring 18 gauge or whatever.)
Gently push it through the clogged port to break up the tarred gunk,
follow with a healthy spray of cleaner.
Use the pipette and carb spray to back blow the ports in the main
intake of the carb also. This'll clean out the primary suction port
that runs through the welsh plug and the seconday that runs through
the primer bulb housing.
Let parts dry or blow off with compressed air, then reassemble carb.
