I'm having troubles with my remote start and i have experience in digital electronics but i have a question. Ill make this short, back in July, i had shut my car off after driving it and the starter automatically turned on and i could not get it to stop. I ended up unhooking the Negative battery terminal and just guessing, taking out the remote start main unit. That solved my issued. Ive been driving the car without it ever since.
Now im trying to get it to work and its quite simple how it works im learning. The starter wire goes directly from the main box to the cars factory wire. And it looks fine so that's not the issue. Someone in another forum said that if i have continuity between the starter output and any of the +12V inputs, then it was a bad relay. Theres 3 relays. I know at least one is for the parking lights. On the bigger one, I do get continuity between all 4 poles, but i can not find any info on it because there is not part numbers or anything on it.
Can anyone help??
Could it be that relay? If so, what is it? I think its a DPDT but not 100% positive.
Thank you in Advance!
Thekidinbuff
Can anyone help??
Thekidinbuff
