I am working on a car project where I have had to add a second fuel pump to supplement added horsepower. The original fuel pump is controlled by a module that looks to vary the voltage to speed the pump up or slow it down. I dont want to pull too many amps with 2 fuel pumps wired in parallel to the original module so I am wondering if I can use the output voltage of the original module as an input to a SSR that will then copy the same voltage but will be able to handle 30 amps with ease. I have ran these pumps on a duty cycle also so I am okay if the output in a PWM signal.
Platforms
Content
