Help with Phillips/Magnavox 17" monitor 107E
Michel Savard
I have this monitor dead which ticks, power supply is definetly good but something in the high voltage must be shutting it down.
I have checked for bad caps all around
I have replaced the IC for the defection without luck
I have tested and replaced anyway the horizontal O/P transistor/thyristor
Don't know what else to look for.
Has anyone found a a weird component faulty on these monitors?
Thank you for your help
K
Ken
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<p>I have checked for bad caps all around
<br>I have replaced the IC for the defection without luck
<br>I have tested and replaced anyway the horizontal O/P transistor/thyristor
<p>Don't know what else to look for.
<p>Has anyone found a a weird component faulty on these monitors?
<br>&nbsp;
<p>Thank you for your help</html>
