No picture and sound together, usually points to a defective power supply, or there is a failure on one of the other boards and the power supply is in the protect mode.
These sets are normally serviced by doing board swaps, as just like servicing a computer. In some instances the new board may require some calibration. For this you would have to consult the service manual. You will also require the proper test and calibration equipment to make the adjustments.
If the set is more than about two years old, replacement boards may no longer be available. Call the manufacture tech support for proper and accurate information.
Jerry G.
