I'm a new to PCB design and after reading several articles and books, I felt pretty confident at designing my circuit in software. I have tried using Eagle, Orcad and Proteus; but have failed in epic proportions. I'm not designing something awfully complex:
-This circuit is connected to the power supply of 120VAC so I need to use a Transformer to lower the voltage.
-The microcontroller takes inputs from external devices, meaning that I need to use connectors.
Now, here are the problems I'm facing:
-I haven't found a way to put the transformer in the PCB! In CAM software they're always a generic type and I'm unable (or at least haven't found how) to fix the size or values of it. Do they need to be outside of it? I don't think so, I have seen many PCB's with embedded transformers.
-What about the connectors? I don't seem to find the ones I need, there's even USB connectors but not a single AC male connector for energy supply. I have some PCB connectors from specific manufacturers, which I'm gonna use for manufacturing; where can I find them? Do I need to do custom components? How the hell do I do them??? I can't find accurate info about it anywhere!
-Why can't I find some components in SMT or TH package? I have seen those components in both technologies.
Can you help me out? Have you faced those problems before? If you haven't, could you give me some orientation towards a great book or tutorial on PCB design for manufacturing (for Eagle or Proteus)?
Thanks in advance
Thanks in advance
