Hello!
I own a radio Sony ICF-SW35. I want to attach an FM Stereo indicator. The radio has a circuit named CXA1238S. Pin 4 is for FM Stereo LED indicator and is not connected from the factory. From datasheet, I have seen that this can be accomplished by connecting a LEd in series with 2.2 kOhm resistor to pin 7 (Vcc). My problem is the following: the receiver is started using a button power on/off which send a DIGITAL command to entire circuit. What happens if I attach a LED ? This supplementary current will create a problem?
Thank you!
Thank you!
