I am trying to fix a 4 digit frequency display on a Dittel FSG 60M avionics transceiver. The radio is 25 years old and works perfectly, but last summer the frequency display began
to occasionally show all 8s instead of the tuned frequency. Gradually this got worse to the point where it now only shows.8's (although randomly it will occasionally show the correct frequency,
and if you drop the operating voltage on the radio below 5 volts the correct frequency will appear). I have a maintenance manual and a complete schematic for the radio.
The display board is relatively simple with very few components. I have measured the logic inputs on all of the driver chips and they are correct. All resistors on the board check out.
I don't have a good way to check the capacitors. The multivibrator chip is putting out a 5 volt square wave at oscillator pin(13) and at Q+ and Q- pins(10&11).
The Q outputs are half the frequency of the oscillator output. The LCD display is a mystery to me. I have no data sheet for it but the connection to the PCB is through elastomeric connectors.
I have attached a copy of the pertinent part of the schematic and pictures of the physical board.
Any help appreciated.
Unfortunately my photos cannot be uploaded for some reason
[edited by a moderator ... Please DONT do underlining like that again !
Also broke up the long string of text into something easier to read]
