Sir bigone5500 . . . . .
In reviewing your files. I just took them and "cut and pasted" them into a graphics editor, with my option of
using Infaview or Paint. Since Paint is already in just about EVERY computer, I used that.
Once it is displayed, you then single right mouse click on the image and, by use of the very bottom option of the dropdown menu,
it will instantly reverse your black and whites. Like . . . . .BAMMMMMM.
Then you copy and carry on back to your preferred storage medium.
Since you composed this at 893% (so says the PDF info) you have a literal TON of pixels for super definition, and it can then be
shifted on down to a 1:1sizing in FINE order.
Your first two pics had some eight or so stray single lines across them and some abberations, but I corrected those images.
I left a little excess coverage around your single perimeter line .
I also couldn't confirm the up is down, down is up and right is left, left is right aspects. . . but it looks like a 7800 series regulator IC layout and its associated bypass, filtering and decoupling caps, folded and vertically mounted.
Here is the result:
(If you want to use them, just do a Prt Scrn capture of the image and then separate /paste them into your storage choice.)
ALSO . . . . just in case the above does not mag up adequately/correctly . . . . here is direct contact to image site
http://i.imgur.com/KaaFN5l.png
73's de Edd
