Alright guys, I've got a bit of a conundrum here and I'd be interested to see any of your solutions as to how to deal with it.
Put simple (and confusing, ironically), I need to find a way to pack an AES-256 or -128 encrypted plaintext into 16 bits of data such that after transmission over a line, there is a manner by which to decode all 256 bits of the data to reverse the cipher.
In a nutshell, I'm working on a project for research on the feasibility of using the Rijndael cipher for audio encryption. Problem is, the small sampling data width of most ADCs rule this out (intuitively), as 16-bit data widths could be BFA'd (exhausted) within the sampling frequency by a powerful enough machine (for example, it would not out of the question for FPGA arrays). My question being, is there a possibility by way operations could be applied to each 16-bit 'chunk' of the output to relate it to each other such that a system on the receiving end could reconstruct the main function.
Here's what I've considered (give me your thoughts; I'll be thinking out-loud):
Eventually, by looking at a simple ladder topology and iterating the above sequence enough, we'd get down to two values. By limiting our input speech bandwidth to 1.55kHz, we could then insert the second 'nonsense' value into the speech pipeline to get the full 3.1kHz voice bandwidth. This is a simple enough operation in theory. But, would this be a reversible process on the end side? This relies on the reversal of a XOR, that it be 'distributive'. Not being thorough in boolean logic, is
It's pretty apparent we couldn't simply truncate the other bits, as that would mean upon decryption we'd have a vastly different result, as AES/Rijndael is a scrambling algorithm.
Code:
// Suppose we split the 256-bit output into 16 16-bit chunks called:
od[15:0] [15:0];
// Then, we XOR each chunk with the next number lower in the series:
output 'N' = od[i] ^ od[i-1];
Code:
a = b ^ c
equal to
b = a ^ c?
