Have a Vintage Kenwood KX-1030 tape deck with noise in the left channel audio. This occurs even when playing back a blank tape, all setting normal or turned off (e,g. normal bias/eq, dolby turned off etc). Using and audio tester (I don't have an oscilloscope) audio was good at the Playback head and through the initial PB circuitry. Then I got to IC 103 (see attached pic) which I assumed was an amp chip of some sort. Audio good at the input (pin 6), then good at pin 5 , 2 and then 3. At the output, pin 7, There is a substantial amount of noise in the signal, definitely not evident on it's right channel counterpart. So I figure either the chip is bad or something driving the chip. So I take some voltage measurements of both left (bad) and right (good) chips. They are:
Left Right
Pin 1 9.4v 1.6
Pin 2 9.6 8.4
Pin 3 10.0 8.8
Pin 4 9.5 8.3
Pin 5 9.4 8.2
Pin 6 9.6 8.4
Pin 7 8.8 15.6
Pin 8 0 0
Pin 9 0 0
Pin 10 9.5 7.8
Pin 11 9.5 2.2
Pin 12 Meter read OL on both?
Pin 13 0 0
Pin 14 15 10
Pin 15 9.6 9.5
Pin 16 18.6 18.6
Obviously something going on here, but what? Further investigation, I find this chip is a NE645B Dolby processing chip, which was unexpected, especially since the dolby circuit is turned of, but apparently their design is to route the audio through it regardless.
So given the relatively high input voltage on pin1 (not the source input to the chip, which is actually pin 5, but one of the stages internally) and low output voltage on pin 7 (even though the output actually is much louder then the right channel one) What might be going on here? Is there come surrounding circuit component I should be looking at closer that is causing the problem, or is the chip simply bad?
Left Right
Pin 1 9.4v 1.6
Pin 2 9.6 8.4
Pin 3 10.0 8.8
Pin 4 9.5 8.3
Pin 5 9.4 8.2
Pin 6 9.6 8.4
Pin 7 8.8 15.6
Pin 8 0 0
Pin 9 0 0
Pin 10 9.5 7.8
Pin 11 9.5 2.2
Pin 13 0 0
Pin 14 15 10
Pin 15 9.6 9.5
Pin 16 18.6 18.6
