So I am wanting to take an 80mm PC case cooling fan and use to cool the power supply I use for my pedalboard. I am just wondering what battery would best serve this purpose. The specs off the manufactuers website says this:
Model No.- CF4SL-UBL
Material PU- plastic
Color- Blue
Dimension- 80 x 80 x 25 mm
Fan Speed-
1500 ± 15% RPM
Air Power-
12 VDC
Noise Level-
≦20 dBA
Operation Voltage Range- 7 VDC ~ 13.5 VDC
Start-up Voltage- 7 VDC
Rated Voltage- 12 VDC
Rated Current- 0.17 A
Lock Rotor Current- 0.07 A
Air Flow-
17.21 CFM
Static Air Pressure- 0.88mm-H2O
Connector- 3-pin and 4-pin
Life Expectation- 25,000 hours
I am very new to this type of thing so I have no idea where to get started. Any advice is appreciated!
Color- Blue
Fan Speed-
1500 ± 15% RPM
Air Power-
12 VDC
Noise Level-
≦20 dBA
Air Flow-
17.21 CFM
