Hello, I'm starting a video surveillance camera project and I would really appreciate your input as to direction and methods.
Here are the details:
-The camera I am using will be activated by a Passive Infrared sensor (PIR) (or also possibly a sound detector)
-The camera must be turned on and started by the sensor, then it must be shut off in the absence of sensor feedback.
Here is how the camera operates normally:
Cam has 2 buttons, 1) ON 2) Start/Stop
- ~2sec After the "ON" button is pressed the "Start" button can be used.
- When the "Start/Stop" button is pressed again, the video will stop & Cam goes into "STANDBY" mode for 65sec
- in "STANDBY" the "Start" button will start recording, but after 65 sec the Cam auto shuts off
(and must then again be turned "ON" before the "Start" can be used.)
Below is the sequence I devised to run the Cam off the motion sensor(s):
I will need to break into the buttons to send the pulses to the camera.
I am considering 2 paths to execute this sequence:
1) Discrete components (i.e. retrigerable monostable vibrators)
2) Programing a microcontroller
This would be my first microcontroller project, but if I do go that route, it appears the Micro could be very basic.
Any suggestions will be appreciated, thanks for reading.
P.S. What line diagram programs do you use?
I did this one in a paint program and I know there has to be a better way!
Thanks.
Thanks.
